Best combination
Old Apr 7, 2006 | 01:15 PM
C5fourJ's Avatar
Default Best combination
As a new member I find the expertise here to be invaluable.
I would like to ask the best combination of air filter and exhaust sytem to get the most HP.
I have just purchased an '04 C5 Com. ED. with 6000 miles. I am new to Vettes and want to keep it as close to stock as possible for now.
Old Apr 7, 2006 | 02:05 PM
PAY2PLAY's Avatar
Default RE: Best combination
Welcome to the site and congrats on your recent purchase. With your exhaust system I think they are all going to give you very close HP gains so its really a matter of what kind of sound and look you are going for. I have the Borla Stingers with the dual tips and I love the way it looks and sounds. It has a very deep throaty sound (although I do get a lot of back pressure popping because I haven't upgraded to long tube headers and x-pipe yet). I also like the look of 2 big pipes sticking out the back. Some people may prefer to go with a quiter exhaust or may like the look of 4 tips instead. With all that being said I would recommend either a Corsa system or a Borla system. They seem to be 2 of the most popular brands but there are a few others out there that have a great reputation aswell. I suggest listening to a few sound clips of different exhaust and seeing which one sounds the best to you. If you look below the picture of my car in my sig. I have a link to a sound clip of my exhaust. Hope this helps and good luck with your research and decision.
Old Apr 8, 2006 | 02:30 AM
Dave01's Avatar
A cat back with get you a few HP and sound much better, but the intake will bump it up at least 10 RWHP. Here's a rundown of intakes (prices may vary):
If you live in California, think twice about the Vararam, as it can be a royal pain to install/uninstall/reinstall for smog tests. If you live in a state that doesn't have visual inspections, then take a look at the following (grouped by cold air and non-cold air, but in no particular order) and my comments, if any:
Vararam: Brings cold air in through the fog light panel area to a panel-type filter. Owners have had good luck with system on the dragstrip, but plan on spending hours to install and a bit more to get everything lined up well. Downside: Eliminates engine bay-cooling air that would've come in from the fog light panels (Z06 or coupe/vert with opened-up panels), so the engine bay may end up being toastier, especially if you add headers later. $350-$400
Vortech Rammer: Brings cold air up from in front of the radiator and into an enclosed box. Its filter is quite a bit smaller than the Halltech Warhead or Blackwing unit. $250
Callaway Honker intake system: This one relocates the MAF so that it is just in front of the throttlebody. It directs cold air from underneath and costs about $500. I believe this unit is 50 states legal (smogwise). Excellent design.
K&N FIPK: This is more of a semi-cold air system, as the cold air intake opening is more of a slit. Its filter endcaps are carbon fiber. However, it is configured similarly to the Halltech Stinger-R and is 50-states legal. $350
Warm air systems: (Easy installation)
Halltech Stinger-R: Not only contains the massive Warhead filter, but also includes a larger-than-stock airbridge and smooth throttlebody coupler. For $239.00 or less, this system represents one of the best bangs for the buck. Fortunately, for about $40, you can add cold air induction. See my procedure at http://www.conceptualpolymer.com/corvette_c5_corner.htm
Halltech Stinger SSM – 2001-2004 C5 only (new!): This intake system features an even larger filter than that of the Stinger-R, TRAP, and Blackwing. $400
Blackwing: Includes just a large filter, but an excellent one at that. Its cost is close to that of the Stinger.
Volant Twin Cone: This system gives you more open filter surface area than any stock box does and is well suited to an engine bay that gets cold air in from the fog light panels, as the filters are more or less in the air flow path. $265
2002+ Z06 airbox cover: A larger opening allows more air to be drawn in through the filter. Expect up to a 5 RWHP gain from this simple swap. $50
Zip-tie: An easy and inexpensive mod (eliminates the OEM box’s upper lid), but its sealing ability is questionable at best.
How good are they? My experience has shown that most will bump up RWHP by at least 10. The advantage of having cold air is that power will not be "dialed down" under normally hot underhood (and intake air) conditions. You could easily lose 10 HP with a warm air system after engine bay temps rise during slow-moving conditions. Cold air prevents this from happening.
lucifergary1
Mar 20, 2015 12:04 AM
RhodeIslander
Apr 25, 2007 08:59 PM
ernie22golf
Jan 4, 2007 03:13 AM
doc hollliday
Jun 23, 2005 03:11 PM
scooperman28
Jun 18, 2005 01:30 PM
