c5 LEAKing Targa...
So the rubber on my c5 targa is pretty good, no deterioration or anything, however it leaks in the front corners Driver and Passenger sides. Where the targa meets the windshields meets the side window. On the highway in the rain, it doesn't leak... however standing water does find it's way down.
Someone told me you can adjust the clips, and also pull the windows in?
How in the world would you pull the windows in?
And the rear solo clip of the targa isn't pulling it back much anyway. Would it need to pull it back more? It's very tight as it is w/ the front clips.
Thanks
~Kevin
Thanks
~Kevin
However, there were writeups on that c5 forum!
http://www.c5forum.com/cgi-bin/ultim...47.html#000002
http://www.c5forum.com/cgi-bin/ultim...48.html#000002
this adjusts the window tip in to seal better as well
blbcklt1_tb
Jul 31, 2005 03:11 AM
