C5 Manual Tran Shifter
Old Feb 25, 2008 | 09:59 AM
nebrgas's Avatar
Default C5 Manual Tran Shifter
Considering changing OE 6 spd shifter to after-market such as Hurst, etc. This is a stock C5 and I don't race, etc., but want to improve shifting. Anyone have recommendations as to brand, and experience with installation (appears to be all done from the top and not super complicated if one knows how to remove trim. Thanks, Dave
Old Feb 25, 2008 | 07:43 PM
tankerpilot01's Avatar
Default RE: C5 Manual Tran Shifter
I put a Breathless Performance shifter in (http://www.breathlessperformance.com...ts/100-262.asp). If you go to Dave01's page (http://www.conceptualpolymer.com/BPP...%20Install.pdf) he's got a really easy to follow install instructions for the very same shifter. It shifts really smooth and short.
Old Feb 25, 2008 | 09:38 PM
Dave01's Avatar
Thanks, Kevin,
Whether you buy a BPP, Hurst, or Ripper, use the lightest spring for side-to-side springback and consider adding a couple of .05-inch thick copper washers to the detent plunger that is in the tranny case. Doing so will reduce the amount of effort required to engage and disengage the shifter into and out of gear. It has been called the AntiVenom mod, but varies in that you do not completely remove the detent plunger.
Dave
Old Feb 26, 2008 | 01:23 PM
nebrgas's Avatar
Iforgot to add that I have not yetdisconnected the CAGS system andplan to doso using the recommended bypass plug. Does disconnection of the CAGS system affect any aspects of theshifter replacement?
Old Feb 26, 2008 | 06:55 PM
Nope, not at all.....I've bypassed the CAGS on mine, not at all an issue with the shifter. The CAGS plug is under the car.
Old Mar 17, 2008 | 06:22 PM
svt04cobra's Avatar
ORIGINAL: nebrgas
Don't do it! I have friends that have used just about every aftermarket shifter out there. I have been told the stock shifter is the best. You will find the other shifters are notchie, and not as smooth as the stock one. Stick with stock its the best.
Old Mar 21, 2008 | 07:22 AM
JetBlackC5's Avatar
no disrespect cobra,
but You have a cobra..... Have you driven your friends corvette? if somebody is looking for a shorter,more engaging shifter throw I'd say the best you can do it to go after-market. there are many shifters available out there, Hurst is the oldest name in the business all very good products, i had one on my s-197 mustang worked very nicely. Another one that stick out in my mind is the Breathless Performance shifter (BPP) it has a very sturdy feel and MANY many variable adjustments can easily be made to it
Old Mar 27, 2008 | 04:47 PM
svt04cobra's Avatar
ORIGINAL: JetBlackC5
No disrespect to you either but I have a C5. I sold the cobra. My buddies have had their c5/c6's for years now. I know about the after market world as i have been modding cars for the past 15 years, and have been told by many that the stock shifter works the best for smooth shifting. Sure you can get a shorter throw but if the shifter is notchy going into and out of gear then its not worth it IMHO. Thats the only point I was trying to make. If you like that feel in a shifter then more power to ya. One of my buddies just bought the hurst shifter, I asked him how he liked it. He said it is a very short throw, but its notchy. Another friend with a C6 said he tried a few different shifters, all were notchy. Just my .02
Old Mar 28, 2008 | 07:45 AM
JetBlackC5's Avatar
yea its cool. I have a B&M type in mine. I love the feel of it. I finally replaced the stock **** with amuch tighter one.I guess it could be described as notchy, but then again its a shifter not a pillow, why wouldyou want to feel like having long mushy rowing, shifts when you want to maximize your e.t., mph, and seat of the pants dyno feel?
Old Apr 19, 2008 | 09:33 AM
mkaresh's Avatar
Banned
The C6 shift throws are shorter than those in the C5, right? Can those bits be fitted to a C5?
I've driven a lot of cars. Can't say I was a fan of the C5's shifter.
