Heads Up
Old Mar 2, 2008 | 01:05 PM
Architect's Avatar
Default Heads Up
Alright, so the other day my oil gauge was suddenly pegged out. I immediately remembered seing threads on here about the oil pressure sensor, so i looked up an article and changed this out myself this morning. Oil pressure is back to normal.
This has built up my confidence a little, so now I'm wondering how hard it could be to change out the Heads up Display Unit? Mine sat in the sun too long last summer and hasn't been able to move all the way up on the windshield ever since. I've heard of this happening to other C5's, but have any of you out there replaced the unit yourself? I took a peak under the dash and there are a lot of random wires, etc, things that could easily get "messed up" by an amateur. Anybody done this before? Suggestions?
Old Mar 11, 2008 | 10:34 PM
Dave01's Avatar
Default RE: Heads Up
Here are some comments I've seen:
Originally Posted by jmmy [/align]Yeah, pulling the dash was what I'd hoped to avoid. Any body got a set of directions or tips. Since I posted the HUD the oil sending unit died and the passenger window won't come up. I like working on all my cars but this is adding up a little fast.[/align]In your case it's possible you have either a switch failure (controlling the up/down) or a HUD projector drive motor failure.
Most likely however, I would suspect a connector being poorly seated as the problem. Requires IP removal only. I would check to make certain the connectors are fully seated on both ends of the 11 wire connector cable.
Good news: If the switch is bad you only need to remove the IP.
Bad news: If the HUD projector drive motor is bad, you'll be pulling the dash pad again and replacing ($$$) it.
I just installed a HUD system in my 2000 hardtop this past weekend.
Once installed, I discovered that when adjusted fully up, I could see only about 3/4's of the display. However by raising the rear leg (point closest to the steering wheel) I could see the display perfectly. It only required raising the leg about a 1/4 inch, and the rear leg is in a slot so raising it this much was no problem. The difficulty is, if this is your only alternative to pulling the display up, you're gonna have to pull the dashboard... good luck...
sergmeow
Jan 20, 2006 01:21 AM
75Shark
Dec 6, 2005 12:16 PM
SpeedGirl
Nov 15, 2005 12:53 PM
Boshaft
Sep 27, 2005 04:49 PM
BLKDMN666
Jun 14, 2005 07:06 PM
