LOWERING MY "03"
Old Apr 28, 2006 | 08:45 AM
MYROSIE03's Avatar
Default LOWERING MY "03"
I'm serious thinking about lowering my vette about 2 inches in the rear, and 1 1/2 on the front. I was told it's very easy? Just by turning some bolts?
Old Apr 28, 2006 | 02:59 PM
corvette king's Avatar
Default RE: LOWERING MY "03"
YOU WERE TOLD RIGHT. BE CAREFULL NOT TO LOWER TO MUCH YOU WILL DRAG EVERY WEAR YOU GO.
Old Apr 28, 2006 | 07:40 PM
About an inch was best for me. More than that and the car looked too low, and more than that rubbed or corners, too -- of course I have wider than stock tires (275s front, 345s rear), but I had wheels and suspension changes and tubbed wells made to accomodate them.
Old Apr 29, 2006 | 04:12 AM
Dave01's Avatar
You won't be able to lower your C5 that much on stock bolts (longer ones are needed), but I woudn't recommend lowering more than what is possible on stock bolts. Here's a procedure for you:
http://www.frankhunt.com/FRANK/hobbi...5_Lowering.htm
Old May 1, 2006 | 06:53 PM
MYROSIE03's Avatar
Thank you Dave for helping me..
I'm just a little confused by the pictures on the site you sent me. If I tighten the rear bolts, wouldn't that increase my threads? Am I suppose to loosin the bolts and leave a few threads?? This would drop the rear?....correct??
I'm eager to do this, but afraid of causing damage. Have you ever heard of this causing damage?? One inch on the rear is fine with me. I believe it will look noticeable.
Tommy...
Old May 1, 2006 | 07:02 PM
MYROSIE03's Avatar
Also..
I'm thinking about not touching the front, since it's more of a concern when going up steep inclines. You think dropping the rear 1 inch and leaving the front stock height will look ok??
Tommy...
Old May 1, 2006 | 07:05 PM
MYROSIE03's Avatar
hey did you lower your C5 the smae way the web site dave sent me?
If so, how low and did you have any problems??
I'm thinking about and inch on the rear, but NOT touching the front?
Tommy...
Old May 2, 2006 | 03:54 AM
Dave01's Avatar
MYROSIE,
I advise against lowering just the rear. The level of the car must remain the same after lowering, so lowering just one end would not only make the car look weird, but will also compromise handling. Follow the procedures and your car will look much better than it does now. However, if you do NOT have the Z51 suspension option, you may want to upgrade your suspension. I have to be very carefull entering and leaving driveways. Other than that, I have had no problems at all.
Old May 4, 2006 | 03:37 PM
Red Z06's Avatar
I lowered the rear using the stock bolts, I dropped one inch leaving two threads exposed.
I went from 29" from the garage floor to the center line of the fender well to 28".
Yes I know I should measure chassis dimensions, but I wanted it to look straight since I'm not really interested in how it will handle at 178 mph!!! I only get reach 105-110 when I'm getting on the freeway and usually let off when I shift into 4rth.
With the one inch drop the car rides firmer and the freeway bumps are more pronounced in the Dallas ~ Fortworth area.
Old May 10, 2006 | 12:07 PM
50annv03's Avatar
where do i look to find out what suspension package i have, 2003 c-5 anniverary package, i do have ride select(sport or tour) not sure if this was in all 2003 vettes. if i lower3/4 in the front and 1" in the back do i need a front end alighnment.
