MN6 Column Lock Bypass????
When I purchased my car it had not been done yet, but when I took it to the local Chevy dealer they punched the vin # in and it gave them a list of any recalls that have not been performed yet. So you could call your local Chevy service department with the vin and they should be able to tell you if it has been done yet.
If it is NOT installed, you will hear a "Bzzzzzt" when you turn the ignition key to the ON position, Likewise, you will hear the same noise when you turn the ignition key off. In addition, the steering wheel will be locked after you turn the key off.
Paytoplay,
I believe he's talking about the bypass, not the recall. The recall won't fix a C5 with MN6 tranny. I know because I had the recall done just before my column lock relay failed completely. After having my car towed to the dealership for a replacement, I promptly installed the bypass and should never have that problem again.
Dave
Dave
NYOverlord
Jan 17, 2016 12:12 PM
studlee2
Feb 21, 2008 12:10 PM
