Noise in the back of the car
Old Sep 21, 2007 | 07:40 AM
kuwait_vette's Avatar
Default Noise in the back of the car
i have an annoying sound coming from the back of the car
it only comes when i put my feet on the pedal and hit the gas
when i remove my feet it stops
it comes when i hit 80 Km/h and up
is it the differential? and whan can i do to eliminate this sound?
i tried the differential sound eliminator oil, nothing happend, still the sound is coming when i hit gas
it's sounds like F1 car naaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa aaaaaaaaaaaaaaaaaah
anyone knows what to do?
Old Sep 21, 2007 | 10:23 PM
Dave01's Avatar
Default RE: Noise in the back of the car
Has the previous owner ever changed the diff? Did you physically check underneath the car for leaks in the exhaust? I would do that, first.
Good luck.
Old Sep 23, 2007 | 03:04 AM
I checked, the exhaust is good, the sound is more like coming from the diff not the exhaust
and the Diff is stock...
i think I'm going to change it coz it might be some of the parts inside the Differential is cracked or something.
my friend has a 3.7 diff, if i want to install it on my car, do i have to change other stuff?
or should i search for a stock diff? and what is the number of it? 3.4?
my car is 1998
Old Sep 23, 2007 | 07:10 AM
Difs are interchangeable. You would have to change the speedo gear in the tranny, to get the speedometer to read correctly, if you change gear ratio in the dif.
Old Sep 25, 2007 | 02:19 AM
thanks for the info
best regards
Old Sep 25, 2007 | 11:09 PM
Dave01's Avatar
ORIGINAL: C3 Starship
This is true ONLY if you have an auto tranny. The MN6 does not require any speedo gear change. By the way, the first thing I would do is change the diff fluid and if you use the GM stuff, add the friction modifier as well. This could solve your problem without any other changes.
The stock diff in an MN6 C5 is 3.42:1. Optional diffs are 3.7, 3.9, and 4.1.
AmericanCarCraft
Mar 14, 2013 08:35 AM
AmericanCarCraft
Mar 14, 2013 08:34 AM
AmericanCarCraft
Mar 14, 2013 08:33 AM
AmericanCarCraft
bill
Nov 14, 2006 03:16 PM
