Radar detect into mirror
Does anybody know the place or person that has the wire connect for radar to the mirror so I can get rid of that phone cord thanks norlund1:eek:
RE: Radar detect into mirror
i would check with mobile audio and security shops.
I dont know about a pre-fab connector but i wired mine up directly to the wiring the used heat shrink so it looks pretty much factory. here is the wiring if you need it.
PIn A - orn = batt + ( always on ) Pin B - orn = batt + ( always on ) Pin C - blk = Ground Pin D - brn = Park lamp feed + ( this only has power with the parking lights on ) The only problem with this is that you need to make sure to turn off your dector when you get out of the car [sm=americanasmiley.gif] |
