Radar detect into mirror
I dont know about a pre-fab connector but i wired mine up directly to the wiring the used heat shrink so it looks pretty much factory. here is the wiring if you need it.
PIn A - orn = batt + ( always on )
Pin B - orn = batt + ( always on )
Pin C - blk = Ground
Pin D - brn = Park lamp feed + ( this only has power with the parking lights on )
The only problem with this is that you need to make sure to turn off your dector when you get out of the car
[sm=americanasmiley.gif]
