Ramps
Old Apr 9, 2008 | 02:16 PM
nebrgas's Avatar
Default Ramps
Guessing this has been discussed previously, so bear with me. Am relatively new C5 owner who prefers to do my own oil changes and knowwhat I need, just unsure of best equipment. I have a set of theyellowmetal ramps with plastic extenders that may work, but not very wide and Ilike theidea of the lightweight plastic products. I can buy Rhino ramps (8000# or 12000#) for <$50 or Race Ramps for $200+ depending on regular or XT model. Have not seen either in person, but pics of Race Ramps appear to be longer with lower approach angle. So, does $150-200 more for the RaceRamp buy that much more quality, etc. Thanks
Old Apr 9, 2008 | 11:10 PM
Default RE: Ramps
These worked fine - 2 x 6's; I've got 2 x 8's cut now. $0, 10 minutes.
https://www.corvetteforums.com/m_35150/tm.htm, post 4
Old Apr 15, 2008 | 11:42 AM
Cheftic's Avatar
Default RE: Ramps
I use the rhino ramps w/o any issues
Old Apr 19, 2008 | 01:10 PM
Dave01's Avatar
Default RE: Ramps
Rhino ramps will work just fine if you have not lowered your C5 with the factory adjusting bolts. The flexible spoiler will scrape a bit with a non-lowered C5, but rubbing on plastic ramps does no harm.
If you do lower your car, you can either get some mini-ramps or build your own from 6x6 wood. I drive up on the wood mini-ramps (fron and rear) and then (after placing wheel chocks behind the back tires) jack the whole front end up with a floor jack. I then place the Rhino ramps under the front tires and then jack up the rear (for changing the oil). Jack stands with wooden caps hold up the rear.
Race Ramps are nice but very expensive.
LT4Dave
Oct 31, 2006 04:40 PM
