Suspension options
Old Apr 17, 2006 | 10:29 PM
Wally Hendrickson's Avatar
Default Suspension options
Which of the suspension options is the better handling...Z51 or the FE45 adjustable. You would think that the adjustable suspension which cost 1600+ would be better than the cheaper Z51. Although I imagine that the Z51 is a no compromise track suspension.
Thanks for the info.
Old Apr 17, 2006 | 10:34 PM
Default RE: Suspension options
The Z51 is a no compromises suspension -- track, not quite, but definately tuned for handling above all else. The tuneable suspension gives you a range, from smooth and a bit softer to a just a bit less than the Z51. It also weighs a bit more where a suspension would not -- not enough that the additonal weight matters unless you are going for near racetrack levels of performance, but a bit more nonetheless.
Old Apr 18, 2006 | 12:54 AM
Team 4R's Avatar
can i ask a follow-up...?
the original post seems to imply that the non-adjustable suspension in the standard corvettes is the z51 suspension. am i correct on that? is it safe to say that a non-z06 corvette that does not have the suspension adjustment switch on the center console came equipped with the z51 setup?
Notorious
Jun 25, 2007 10:30 PM
PAY2PLAY
Jan 3, 2007 01:04 PM
briancuss
Oct 10, 2006 06:41 PM
briancuss
Aug 26, 2006 12:36 PM
DISCMAN68
Apr 20, 2006 01:30 PM
