Transmission Temp High
Old Mar 1, 2007 | 06:11 PM
snidehockey's Avatar
Default Transmission Temp High
Hello I have a 98 Lingenfelter C5 that keeps giving the message 'Trans. Temp High' then just says trans fluid HOT. Can anyone shed any light on any possible causes or reasons for this issue? Changing the fluid on this beast seems like quite an undertaking too!
Thanks!
Danny
Old Mar 1, 2007 | 06:38 PM
Default RE: Transmission Temp High
Well, there are only several things it could be:
bad sensor or indicator.
low fluid
internal gear problem
trans fluid coller stopped working (assuming your Ling has one)
I'd check the fluid level and top it up. It's not that difficult to change or add fluid -- alot cheaper than replaceing a trans.
Old Mar 10, 2007 | 10:10 PM
Black86vette's Avatar
Flush out the tranny and see if it helps it out.
chetastor
Corvette C6 Z06
Aug 24, 2006 10:03 AM
ocon0950
May 3, 2006 02:49 PM
swlsn
Apr 10, 2006 05:43 PM
PAY2PLAY
Oct 10, 2005 06:58 PM
HillSmith
Sep 6, 2005 11:53 PM
