08 back to the dealer already
well sunday afternoon i figure i'd take the car out for a little bit, so after a lil beating onher i go and press the clutch pedal againand there is no pressure in the pedal! it was either to the floor or all the way up, no in between, so after that it was back to the dealership! they told me i fried the slave cylinder because the hydrolic fluid got so hot....anyone hear of this problem before? should be fixed by tomorrow.....
This is a common problem at the drag strip. If you do too many runs back to back, usually three will do it, you lose the clutch pedal just as you described. Lettingthe car cool down will usually fix things with nopermanent harm done.
gmpartsland
Jan 6, 2007 07:45 PM
1990polo green
Aug 31, 2005 10:51 PM
