2005 Intermittent Errors
Newbie to the forums; I haven't seen anything like this, have you?
2005 Coupe, intermittently reports "Right Rear Tire Flat" but clears itself after a minute or so, and tire isn't flat. Also, highly intermittent "Service Active Handling System" usually right after starting or just beginning to move. Have checked under battery, no signs of leakage, checked a few ground connections but nothing flaky discovered yet. Ready to pick up a CANbus OBDII scanner, but have also heard a couple other 2005 owners experiencing the same exact problems. Anything known in this venue about the possibility of something that has been identified as problematic, but that has a simple (low cost) fix? Anything you folks might know would be much appreciated! Joey |
