Corvette C6 Forum 2005+
2005 Intermittent Errors
Old Jan 4, 2010 | 04:33 PM
Joeys_C6's Avatar
Question 2005 Intermittent Errors
Newbie to the forums; I haven't seen anything like this, have you?
2005 Coupe, intermittently reports "Right Rear Tire Flat" but clears itself after a minute or so, and tire isn't flat. Also, highly intermittent "Service Active Handling System" usually right after starting or just beginning to move. Have checked under battery, no signs of leakage, checked a few ground connections but nothing flaky discovered yet. Ready to pick up a CANbus OBDII scanner, but have also heard a couple other 2005 owners experiencing the same exact problems. Anything known in this venue about the possibility of something that has been identified as problematic, but that has a simple (low cost) fix?
Anything you folks might know would be much appreciated!
Joey
3BlkC4Ragtop
Sep 29, 2007 09:01 PM
moscooter
Aug 3, 2007 10:37 AM
Petew1971
Mar 7, 2006 02:04 AM
mlrutland
Feb 17, 2006 09:52 PM
jefftwilley
Dec 9, 2005 12:11 PM
