Corvette C6 Forum 2005+
Need help removing writing from window
Old Jan 22, 2007 | 12:41 PM
vette girl's Avatar
Default Need help removing writing from window
Hello all,
The dealership that orginally had my vette wrote on the driver side window with (I'm assuming) grease pencil or shoe polish. In certain light, you can still see the shadow from the writing. Does anyone know how to get this off? The guys atmy dealership said to use vinegar and a razor blade, but that didn't work.
vette girl
Old Jan 22, 2007 | 12:46 PM
SilverSurfer's Avatar
Default RE: Need help removing writing from window
There are two products which I would recommend. WD40 and/or a "Bug & Tar" remover product may help dissolve the compund used. I have found this to be quite effective. Also once cleaned, make sure you wash it with a product like Dawn as the alcalyn base will breakdown any furhter wax residue.
that is my 2 cents worth. Good luck.
Old Jan 22, 2007 | 01:26 PM
vette girl's Avatar
Thanks so much for the recommendation! I'll try them out this afternoon.
vette girl
Old Jan 24, 2007 | 04:44 PM
extanker's Avatar
big diff between grease and shoe polish. wd 40 or avon skin so soft both will not hurt anything but they need time to work
Old Jan 25, 2007 | 02:51 AM
corn starch past left to dry in the sun Draws oil out of concrete, maybe it will work. good luck
Old Jan 25, 2007 | 03:59 AM
gorichb's Avatar
WD-40 should do the trick, Amazing stuff.
also, if by chance it don't work than 3M adhesive remover will work for sure. I know your thinking it's not adhesive, but it will rid your window of the film you see,
Old Jan 25, 2007 | 07:00 AM
extanker's Avatar
ORIGINAL: blueshark
will it work on black top too
Old Jan 25, 2007 | 02:58 PM
vette girl's Avatar
True enough that there's a big difference between shoe polish and grease. Unfortunately I don't know what they used. You guys have certainly given me a lot of options to try. I really appreciate it! As soon as itFINALLY stops raining in my neck of the woods, I'll give them a try. Nothing like buying a black car just prior to a month's worth of rain. AUGH!!!!
vette girl
Old Jan 25, 2007 | 03:56 PM
ORIGINAL: extanker
ORIGINAL: blueshark
corn starch paste left to dry in the sun Draws oil out of concrete, maybe it will work. good luck
not sure but worth a try.
Old Jan 25, 2007 | 07:51 PM
gorichb's Avatar
ORIGINAL: vette girl
vette girl
Vette girl
if it rains really hard maybe you'll get lucky and it will take care of the marks for you
