Tpms
Im new to the Vette family, and have question concerning my TPMS, took factory rims off my 2006 and replaced with factory rims off of 2014 stingray, did not change sensors, display showing, all tires flat, tire service monitor, is there away to turn off/reset, until I replace rubber and mount old sensors?
You'll need to go thru the programming sequence. Should be in the owner's manual. I suppose the '14 sensors might not be compatible tho. If that's the case, then you'll probably have to live w/ it unless a scanner can turn the DTCs off.
