Corvette Youtube channel
The dark, gooey graphite looking substance that you were wiping off of the drain and fill plugs was microscopic particles of steel. You will see this most commonly on magnetic drain plugs for engines but obviously can also occur in differentials. It's my opinion that this generally occurs on new engines, transmissions, and differentials as the metal parts wear in to each other.
Don't think it would hurt anything as long as the magnet was pulling out of the oil. What you drained out sort of looked like it might have had some water in but was watching on my phone so hard to tell.
Here's what I use to keep whatever fluid I'm draining off of everything. It's lead encapsulated in Buna-N rubber.
It's flexible and can be shaped however you want it.
https://formafunnel.com/product/truck-and-tractor/
