Corvette C7 Forum 2014+
Non starting due to anti theft mode needing service.
Old Aug 17, 2023 | 02:08 AM
robsynrs's Avatar
Question Non starting due to anti theft mode needing service.
I have a 2016 c7 and is having issue on theft device needing service on dashboard. I cant restart the car and it evenbtually drained the battery. Whatr is the procedure to service tore, air bag and anti theft showing on dash
Old Aug 17, 2023 | 07:44 AM
Welcome to the forums. Only three things can cause this that you need to figure out. Service manual would help, Cars battery needs to be in good condition and charged. The fob must have a good battery and condition and operating correctly, you can try using your second fob to see if that helps if you have one. Or there is a malfunction in the system. Charge or change batteries, get in the car and lock the doors, turn on the ignition with push button or the key if possible. If you can't get good results it might need professional help at a shop.
PHXC7
Apr 16, 2022 09:32 AM
PHXC7
Apr 1, 2022 01:38 PM
25C8Z06
Apr 1, 2022 09:23 AM
01pewtertg
Jan 22, 2007 12:12 PM
jimmizvette
Nov 29, 2006 10:46 PM
