Corvette Forums Help & Suggestion Center Need help with Corvette Forums? Ask. Have a suggestion to better CF? Tell us here.
84 Vette
Old Jul 20, 2014 | 11:54 AM
brownd355's Avatar
Default 84 Vette
I just bought my first Corvette. It is a completely stock 84 that has been sitting for over 5 years. I bought a service manual and have spent a lot of time reading. My problem is the engine will not crank over. Also the instrument lights, head lights and horn do not work. I checked the main fuse panel and all is good there. The radio, turn signals and marker lights all work along with the brake lights. I installed a new battery and the fuseable link is fine. Can someone tell me where to go next.
Old Jul 21, 2014 | 12:59 PM
You'll need to start checking voltages starting at the ignition switch and see where you are losing it. But I'd first check at the solenoid and starter to rule out a bad component
