overfilled master brake cylinder
I just had front and rear brakes put on my C6 Corvette. I also had the brake fluid changed. After arriving home, I noted that the level in the brake cylinder was over the max and near the lid. Knowing this fluid heats up, I waited to check the level in the morning. It was cooler but was still above the max line. Can I simply remove the excess with a turkey baster and be OK, or will I cause problems?
