Corvette Forums Help & Suggestion Center Need help with Corvette Forums? Ask. Have a suggestion to better CF? Tell us here.
overfilled master brake cylinder
Old Sep 6, 2019 | 09:07 PM
Bob Depue's Avatar
Thumbs up overfilled master brake cylinder
I just had front and rear brakes put on my C6 Corvette. I also had the brake fluid changed. After arriving home, I noted that the level in the brake cylinder was over the max and near the lid. Knowing this fluid heats up, I waited to check the level in the morning. It was cooler but was still above the max line. Can I simply remove the excess with a turkey baster and be OK, or will I cause problems?
del23t
Feb 5, 2017 03:06 PM
Ecobrakes
Apr 22, 2012 02:38 PM
najaf4life
Oct 18, 2008 06:52 PM
mrrx8
Apr 5, 2008 07:54 PM
kcclark66204
Jun 5, 2007 04:00 PM
