1984 fuel pump
Old Jun 23, 2007 | 07:26 PM
tattoo's Avatar
Default 1984 fuel pump
How hard is it to change the fuel pump on a 1984 ? Thanks in advance.
Old Jun 23, 2007 | 08:33 PM
Default RE: 1984 fuel pump
Not hard at all really, but a real mess.
Empty the tank, disconnect emission vacuum hoses and electrical connections, and drop the tank.
Getting the tank access ring loose is not easy - you have to use care, and more importantly, try to clean loose dirt around every thing that you disconnect/unscrew, and make doubly sure that all connectors are clean before re-connecting...
Are you sure that your pump is toast?
Old Jun 23, 2007 | 08:40 PM
tattoo's Avatar
The car is running rough at idle. someone told me it could be the fuel pump. doing tune up tomorrow hoping it will come out of it.
Thanks
Old Jun 23, 2007 | 08:53 PM
ORIGINAL: tattoo
Thanks
Rough? As in loping? Rev'ving up and down?
Old Jun 23, 2007 | 09:12 PM
tattoo's Avatar
Not really , the idle does not jump up and down . more like a sputter.
Old Jun 23, 2007 | 10:17 PM
The sputter could be several different things. Coil, Distributer cap, Rotor, ECM in the dist.or lack of litheum grease on the ECM, bad plugs even dirty injecters. Do a basic tune up (plugs, wires, rotor, cap, )first and see if that helps. While doing the rotor and cap check the ECM for cracks to it's body and connecters and look for white lithium grease on the under side. Good luck with it and let us know if you get'er squared away. Cheers
Old Jun 30, 2007 | 01:47 AM
vfw no. 11548's Avatar
I don't remember dropping the tank...I think you can access the unit from the top on a 84
Old Jun 30, 2007 | 02:16 PM
Superdzzz's Avatar
Maybe I missed what you said but did you already change the fuel filter?
Cheap and easy[sm=icon_cheers.gif]
Old Aug 7, 2007 | 02:27 PM
84corvetteC4's Avatar
your fuel pump is the last thing you wanna change (most expensive and hardest) explore plugs wires cap and rotor first before anything too see if that clears up you problem
Old Aug 8, 2007 | 09:16 PM
Superdzzz's Avatar
ORIGINAL: 84corvetteC4
Like I suggested, did you try the fuel filter?
Never heard a reply[sm=icon_cheers.gif]
