85 vet. left rear popping,squeeling on rotation
85 vette, popping,squeel from left rear. It is a rotational noise, I think its either the u-joint, or the wheel bearing. Please resond. Is this a common problem?
RE: 85 vet. left rear popping,squeeling on rotation
I don't know, I have an 1985 vet too and mine doesn't do that, but thats just me.
I just had a similar problem with my 87 vette and it was the left rear outer u-joint. Cost me nearly $300 to have it fixed.
Hi I had the same problem and yes it was a u joint in my case. I did repair myself but had to take in to realign camber ajustments. I hope I helped you in some way. Frank85
hello ,all of the advice above sounds correct,check all your joints and wheel berings,both will make a simular sound, and this mite sound crazy check your lug nuts to, i have had a customer bring vette to me with a clicking sound and the rim was loose,
good luck my friend [IMG]local://upfiles/1664/BDC0C063985247D4A2AC0DD4DDE56C3B.jpg[/IMG] |
I agree, it sounds like universals to me. [&:]
