C4 Vette looking for help
ya that will help worth about....16-25 hp.,,,,a k& N AIR CLEANER 10-15 HP. SET OF ROLLER ROCKERS 1.6 RATIO 15-20 HP.HEADERS LONG TUBE ..10-15 HP...PULLY KIT 15-20 HP,,,,HIGH ENERGEY DISTRIBUTOR.... 10-15 HP...58 THROTTLE BODY, MY BE 15 -20 HP.DEPENDS ON ENGINE SET UP, YOU HAVE A 1000. DOLLARS TO SPEND, IF IT WAS ME..... ROCKERS 1.6 WILL GIVE YOU SOME MORE LIFT 15- 20 HP, PULLY KIT 15 HP GAIN.CHIP 16 -20 HP GAIN .K&N FILTER 10 HP GAIN.. SOME HEADERS 15 - 20 .HP GAIN.. X PIPE, HIGH FLOW CATS, OR REMOVE CATS, AND SOME GOOD MUFFLERS, FLOW MASTER OR MAGNA FLOW, GOOD FOR 15 HP GAIN THATS ABOUT 76 HP GAIN BUT THESE ARE ALL ESTIMATES, I NO GEARS ARE EXPENSIVE BUT CHANGING THEM TO 373 WOULD BE LIKE ADDING 50 MORE HP, THE CAR WILL LAUNCH BETTER AND HAVE GOOD MID AND TOP END. HOPE THIS HELPS,
[IMG]local://upfiles/1664/5B58AD066A9444DFB0F1E91874057610.jpg[/IMG]
Thank you king, that is what i was looking for, just one other question regarding the 1.6 rocker arms, i have stock cast heads will the 1.6 rocker arms be to large for my stock application , meaning will they hit the stock valve covers???
i would put on some taller valve covers. crome. cost only $20.95 .from summit, just to be safe.
http://store.summitracing.com/partde...5&autoview=sku
set your regulator to 45 lbs, hear is some good info on setting your injectors,by the way i was wondering if you had center bolt valve covers or the 4 side bolts
http://www.megasquirt.info/v22manual/minj.htm
