changing brake light bulb
1989 vette
Underneath top of glass hatchback has 2 star shaped bolts that I assume has to be taken out to get to the brake light bulbs. Is this correct and does anyone know the size of star wrench I need. The hard top star wrench is to big. Also, the red lense cover, for the bulbs, has a small slot (about the size for a flat screwdriver to fit in) located on the bottom in the middle of lense. I tried going this route but was afraid of breaking red plastic cover. Just wondering if slot is for getting to bulbs this way. Any help is greatly appreciated! Mike |
RE: changing brake light bulb
ORIGINAL: mrg404 1989 vette Underneath top of glass hatchback has 2 star shaped bolts that I assume has to be taken out to get to the brake light bulbs. Is this correct and does anyone know the size of star wrench I need. The hard top star wrench is to big. Also, the red lense cover, for the bulbs, has a small slot (about the size for a flat screwdriver to fit in) located on the bottom in the middle of lense. I tried going this route but was afraid of breaking red plastic cover. Just wondering if slot is for getting to bulbs this way. Any help is greatly appreciated! Mike You can get away with using a hex/allen wrench, but for load-bearing bolts, that's a no-go. You might need a new gasket when re-assembling... |
