Charging problems !!!
I have an 82 with a charging problem. The volt gauge is reading up around 17 volts, and if the car sits for a week or two the battery is completely dead. It is a brand new battery and i've returned it to the parts store where it was recharged and tested, the battery is ok. Is it possible that the voltage regulator is bad ? Any help would be appreciated. Thanks.
RE: Charging problems !!!
it sounds like it, 17 volts is way to much!should be 14 to 12 volts , to much voltage is no good,have your alternator checked out,[8D] also check and see if you have any draws in the car,like radio,lights,ect will draw the battery down.i had a bad regulator in my alt, my battery would be dead in two days,check the alternator first,good luck
Thanks for the feed back Corvette King, Went out and got a new regulator, took out the alt. and removed the back. after looking inside it was quite obvious that the alt. was cooked. put it back together went back and got a new alt.... PROBLEM SOLVED !!! Volt meter now just a hair above 13 volts.
Thanks Again GrtAmrTrkr [IMG]local://upfiles/1422/26F2D0E1DF77483A9F20EDF0ADECD845.jpg[/IMG] |
GLAD YOU GOT IT FIXED. YOU ARE WELCOME ,:DKEEP THE WAVE ALIVE[sm=hiya.gif]
