Horn not working? Has power!
Old Jul 16, 2007 | 08:09 AM
bernie3's Avatar
Default Horn not working? Has power!
Hi. The horns on my 79 just quit working? tested contact area in steering wheel w/ trouble light & it shows power? Any ideas? I'm not a mechanic by any means, so any help or suggestions would be appreciated!!!
Old Jul 16, 2007 | 08:14 AM
wrwalke's Avatar
Default RE: Horn not working? Has power!
If it is the same as my 81... There is a horn relay about 4 inches or so "up" from the fuse panel. If it was an "all of a sudden" failure", this is the most likely candidate. When you make contact in the horn button, you should at least hear the click coming from the fuse panel area.
bill.
Old Jul 16, 2007 | 09:09 AM
drummerjlc3's Avatar
It is the same as 1981, I have a 79 as well and mine done the same thing more than likely this is your problem. Should be a little bleck relay with 3 terminals that plug into a socket in the harness.
Hope this helps
Old Jul 16, 2007 | 09:38 AM
Phill's Avatar
checkall your fuses before you replace the relay. dont just check the horn fuse (hazard fuse i believe) check them all.
Old Jul 16, 2007 | 12:21 PM
ORIGINAL: bernie3
If you got power at the horn button, did you jump it with a piece of wire, to see if the hornbutton is what's failing to make the contact?
EDIT: Oops! Never mind wire! There's a lotta' juice there. Use needlenose pliers.
Old Jul 17, 2007 | 09:45 AM
Phill's Avatar
also check out your horns i believe if one horn is bad it can affect the other horn. just a thought but easy enough to check before you go replacing things.
Old Jul 17, 2007 | 10:16 AM
ORIGINAL: Phill
That might or might not be so phil...
My '87 had the wimpiest horn.One time, I honked at a kid on his tricycle. He didn't look, but he did show me one of his fingers, for his IQ, or # of friends he had, or somethin' like that - ya know. Then he saw it was a car.
I found out later the low horn wasn't working. The high one did, but I wouldn't call what it did 'work'!
Old Jul 17, 2007 | 10:31 AM
bernie3's Avatar
Hi. Thanks for the feedback. No clicking sound from the fuse box. Have checked all fuses & they are ok! Getting a new relay today & going to try that. I'm willing to bet that's the problem? If not, i'll try new horns? Thanks again, Bernie
Old Jul 17, 2007 | 10:35 AM
bernie3's Avatar
Thanks to all you guys for the feedback on the 79 horn problem?????????? Trying a new relay after i get out of work? I'll let you guys know!!!!! Thanks, Bernie
Old Jul 17, 2007 | 12:08 PM
Sounds like you're goin' for the ol' fully automatic assault wallet approach[sm=shootshoot.gif][sm=violent053.gif]
You got power at the horn button. Did you try to jump the connection there? What happened?
Have you tried to jump the horn directly?
