Silicon Brake Fluid
Old Apr 13, 2007 | 09:39 AM
basbol13's Avatar
Default Silicon Brake Fluid
I own a C3 and I am having a problem with lock up in myright rear caliper. The prior owner recently changed from silicon brake fluid to dot 4. Could this be the problem?
Old Apr 13, 2007 | 11:03 AM
extanker's Avatar
Default RE: Silicon Brake Fluid
yes it could and many other things.brake fluid could have gotten on the pads from bleeding.is the cali. sticking.try bleeding to see what comes out of right rear.is the left side working
Old Apr 13, 2007 | 09:41 PM
basbol13's Avatar
Left side works fine. I tried to bleed but didn't help.
Old Apr 13, 2007 | 11:56 PM
extanker's Avatar
pull the pads see if they have any stains on them if ya get willing to work a little ,swap the the pads from left to right. i had a 74 i got brake fluid on one side and it pulled,i tried soaking them in alcohol,brake clean. nothin helped till i put new pads on.check basic eg cali. slides,any diff on pushing the pistons back in the cali.
Old Apr 14, 2007 | 09:11 PM
basbol13's Avatar
Thanks for the advice I will try this though I won't be able to get to it for a couple of weeks. When I do I'll let you know what happened.
thanks again.
Old Apr 14, 2007 | 09:20 PM
78buckshot's Avatar
Are you sure it's the disc brake? if the parking brakes have'nt had any attention I would be real suspicous of them, they deteriorate quickly and can jam up and cause lots of noise. My '78 is a automatic, I gutted the parking brakes and don't plan on running any.
Old Apr 15, 2007 | 10:03 AM
basbol13's Avatar
I've done that and parking brake is working normally.
Old Apr 15, 2007 | 10:13 AM
78buckshot's Avatar
OK on the parking brake, If it were me I would flush the brake system, install new or rebuilt calipers on both sides and refill with DOT3.
Old Apr 18, 2007 | 01:40 AM
pg's Avatar
Calipers on a "C" 3 need to be serviced a lot more often than we would like. There are 4 pistons per wheel and they will leak or bind up every now and then, 78 buckshot gave you the best advise, change both left and right calipers, install new pads and all the rubber lines while your in there and you will be good to go!
I changed everything in 2000, and have changed a leaking caliper on the rear once since than and I just went back to Auto-Zone today for a replacement front left caliper. They are the best for me and my daily driver- they gave me a no charge caliper and free pads for both sides in the front.
As far as the brake fluid, GM calls for Dot 3 and thats what I use. PG
Todd TCE
Aug 25, 2015 09:55 AM
tryck02
May 26, 2007 07:41 AM
*026041*
Nov 30, 2006 01:19 PM
Black86vette
Nov 17, 2006 03:28 PM
VetteThunder
Dec 29, 2005 11:44 PM
