transaxle
Has anyone had any problems with the transaxle? I have an 05 with 4100 miles on it. The other night as I dusted a 71 Chevelle with a claimed 425hp, the transaxle cracked on me and by the time I got home, oil was everywhere.
RE: transaxle
welcome to the forum...i'm sure you'll get the help you need if you post your problem in the correct area! congrats on dusting the chevelle...
RE: transaxle
"...i'm sure you'll get the help you need if you post your problem in the correct area!"
done. ;) Welcome to CF! :) Well, ya might as well open 'er up, or better yet, pull it out. If the case is busted, you have no choice. [&o] |
RE: transaxle
ORIGINAL: sfqinc Has anyone had any problems with the transaxle? I have an 05 with 4100 miles on it. The other night as I dusted a 71 Chevelle with a claimed 425hp, the transaxle cracked on me and by the time I got home, oil was everywhere. |
RE: transaxle
correct^^^:D
RE: transaxle
The transaxle is a know weakness only in cases where the engine has been modified to over 600 lbs of torque, then it is very prone to crack on hard launches. I would be surprised if a stock car could actually crack the case -- are you sure it just isn't a blown seal?
