transaxle
Old Aug 1, 2007 | 08:50 PM
sfqinc's Avatar
Default transaxle
Has anyone had any problems with the transaxle? I have an 05 with 4100 miles on it. The other night as I dusted a 71 Chevelle with a claimed 425hp, the transaxle cracked on me and by the time I got home, oil was everywhere.
Old Aug 1, 2007 | 10:43 PM
pewter2000's Avatar
Default RE: transaxle
welcome to the forum...i'm sure you'll get the help you need if you post your problem in the correct area! congrats on dusting the chevelle...
Old Aug 1, 2007 | 11:13 PM
"...i'm sure you'll get the help you need if you post your problem in the correct area!"
done.
Welcome to CF!
Well, ya might as well open 'er up, or better yet, pull it out. If the case is busted, you have no choice. [&o]
Old Aug 3, 2007 | 02:15 AM
ORIGINAL: sfqinc
4100 miles? You had a dry seal, and it got burned.
Old Aug 6, 2007 | 07:25 PM
84corvetteC4's Avatar
correct^^^
Old Aug 6, 2007 | 07:31 PM
The transaxle is a know weakness only in cases where the engine has been modified to over 600 lbs of torque, then it is very prone to crack on hard launches. I would be surprised if a stock car could actually crack the case -- are you sure it just isn't a blown seal?
sfqinc
Aug 1, 2007 10:43 PM
