Why can't I change user-specific folder and variable names?
Old Apr 22, 2009 | 02:27 AM
Hansika's Avatar
Default Why can't I change user-specific folder and variable names?
Is there any way to modify or delete a 'user variable' on XP Pro without login to the account?
The story is this. I got a laptop repaired but the OS (together with defective speaker and audio board) was re-installed. The problem is the Windows was installed with a username which I would like to replace. Doing through Control Panel-> User Account was successful.
However, %USERPROFILE% and %HOMEPATH% still point to the wrong folder. I managed to modify %HOMEPATH% through "Local Users and Groups" -> Users, but %USERPROFILE% remained not pointing to the new folder under C:\Documents and Settings. Then I decided to add USERPROFILE in 'user variable' to override the value used by XP. Now I can not login any more through regular reboot or safe mode. I still can login as Administrator.
How do I delete USERPROFILE that I created? From regedit, it seems I can only access Environment Variable (user variable) defined by Current User.
ntonkin
Jul 10, 2014 10:50 AM
Cliff R Rowden
Nov 29, 2013 09:39 AM
Time Bandit
Oct 4, 2007 08:23 AM
vette96
Jun 28, 2007 09:06 PM
94blackC4
Sep 8, 2006 02:20 AM
