wire problems
Hey guys , I could use a litttle help on this one . I have a 2002 vette. coupe
I started the car to leave work and I got all kinds of lights on , air bag , brake light and tires pressure was said to be low and it said something like reduce engine power on the display. I also could not get my passenger window up up get that door to lock when I got home . I know about the battery leaking on the harness problem and I am going to check that at work today if I have time . I was wanting to know if there are any problems with door connection or any other connection getting wet and having problems.Any help would be great , THANKS |
RE: wire problems
Hello,
Sounds like it could be a "ground" problem. There are various points in the vehicle where many electrical grounds come together. There are two under the hood, behind each headlight assembly, that are notorious for getting dirty. I would check these first. CG |
