wire problems
Old Nov 20, 2007 | 06:53 AM
cobra3's Avatar
Default wire problems
Hey guys , I could use a litttle help on this one . I have a 2002 vette. coupe
I started the car to leave work and I got all kinds of lights on , air bag , brake light and tires pressure was said to be low and it said something like reduce engine power on the display. I also could not get my passenger window up up get that door to lock when I got home . I know about the battery leaking on the harness problem and I am going to check that at work today if I have time . I was wanting to know if there are any problems with door connection or any other connection getting wet and having problems.Any help would be great , THANKS
Old Nov 20, 2007 | 09:25 PM
Curious George's Avatar
Default RE: wire problems
Hello,
Sounds like it could be a "ground" problem. There are various points in the vehicle where many electrical grounds come together. There are two under the hood, behind each headlight assembly, that are notorious for getting dirty. I would check these first.
CG
Igidy
Jun 8, 2013 03:29 PM
cobra3
Jan 9, 2008 04:08 PM
ffcagle34
May 24, 2007 12:37 AM
Bagpipingjake
Aug 10, 2006 01:23 AM
toml14
Mar 23, 2006 08:41 PM
