Interior & Exterior What have you done to your ride? Customized it? Upgraded rims, body kits, etc.? Talk about it here...
Sponsored by:
Sponsored by:
84 carpeting passenger side
Old May 17, 2006 | 10:52 PM
ttrip's Avatar
Default 84 carpeting passenger side
How do you remove the passenger knee pad which is below the crash pad. So that new carpet can be glued on. I have removed two nuts from studs under dash but pad won't come out. Didn't have this problem on the drivers side. Thanks Tom
Old May 18, 2006 | 03:19 AM
corvette king's Avatar
Default RE: 84 carpeting passenger side
that is a bitch to do, if i were you spray some 3m on the plate and shove the carpet under the lip first and then press on,that is how i did it.i used a brush to apply the glue around the lip.[8D]
Baudier
Jun 19, 2008 10:27 PM
zach562
Aug 21, 2007 07:57 AM
mark m
Mar 16, 2007 03:21 AM
glrock2000
Jan 4, 2007 11:20 PM
Wifes81
Aug 12, 2005 12:28 AM
