fast idle
Old Mar 21, 2007 | 08:30 PM
jjfrbt.84's Avatar
Default fast idle
Hi I need some help. My 1984 corvette first would run then stall and not start for a few minutes then start again. The repair person changed all vaccum lines. the fuel pump was checked and changed. the brain was checked and changed . the car runs now but the engine will not idle down. any suggestions. I am glad I have found this site I hope to share and learn from the best.
Old Mar 21, 2007 | 09:05 PM
78buckshot's Avatar
Default RE: fast idle
Sounds like you still have a vacuum leak, double check all vacuum lines, make sure the throttle body is not bypassing air, PVC hose, ect.
Old Mar 22, 2007 | 12:59 AM
Welcome to CF!
I agree with Buckshot, sounds like you still have a vacuum prob. Check around the carb (throttle body)base, the gasket may have gone bad. Take some thick oil or vaselene and rub it around the base of the carb, if the idle drops,....there ya go! (change the gasket)
Old Mar 22, 2007 | 08:37 AM
extanker's Avatar
with a scan tool [snap on] monitor idle air valve position,some TB, s were gasket eaters
pshiflet
Apr 15, 2008 10:51 PM
stevenngo
Feb 17, 2006 11:45 PM
mike
Nov 22, 2005 12:40 PM
dan murphy
Oct 19, 2005 10:01 PM
Speed Engineering
Oct 8, 2005 07:12 PM
