inner front tire ware
Hello, I have a 2015 Z06 with 17k miles and both inner front tires wore out to the steel belt. Is this an alignment issue and what needs to be adjusted? I appreciate any help. Thank you, Harry
Welcome to the forums Harry. Yes it sounds like an alignment issue. I would have an alignment done when you buy new tires for the front, a good tire shop can do that, have them check for broken bent or worn parts that could relate to excessive toe out condition. have them check alignment on rear wheels also while it's there. Can't have that much wear at 17K. Sounds like an alignment will make it drive like a new car.
