1974 Corvette Convertible
Old Sep 18, 2017 | 12:45 PM
dddbeal's Avatar
Default 1974 Corvette Convertible
Very Nice! 1974 Corvette Convertible with 46,000 miles. Mileage on these classic cars cannot be verified but I had this car check out by a Corvette expert in Dallas and was told he rarely will agree with the mileage on these cars but this one he believed to be actual, it is that clean.
All stock with the exception of a set of headers. Tires look new. Cold New A/C system. Top is in good shape. Shifts smooth, tight steering, brakes stop as they should, you just need to drive this one you will fall in love with it.
The only bad is the driver door either needs to be shimmed or needs new door hinges. The door opens and shuts fine it just sags a little which throws the lines off.
In 1974 there were 37,502 Corvettes produced only 5,474 were convertibles the large majority of the cars were 3 speed automatics this one is one of the few 4 speeds. Meaning of all 37,502 corvettes produced only 3,494 had the 4 speed manual transmission in them. It has the L82/350ci Engine which produced 250HP stock there were only 6,690 L82 produced out of the 37,502 Corvettes in 1974. As you can see this is a more rare set up for that year, impressive car!
If you have looked at these cars like I have and once you see this one you will know $24,000 is not a bad deal. Most of these older Corvettes need anywhere from $10K-$15K worth of work done to them, and that is for the ones going for $16,000.
Text or Call 682-557-3374
