TOP SPEED
What is the fastest you have ever gone in your Vette?
RE: TOP SPEED
Im 22 andhad lost my license for a year before I got this car so I dont drive excessively fast very often. The fastest that I have gone is about 115 on the highway and it was very hard to lay off the gas pedal.
RE: TOP SPEED
An indicated 192 for just a brief instant.
RE: TOP SPEED
Wow, Lee I will be surprised if anyone can top that !What are the specifics of you Vette and does it have any mods?
RE: TOP SPEED
Dude, look in his Signature. It tells it all right there.
RE: TOP SPEED
ORIGINAL: Drdino52 Wow, Lee I will be surprised if anyone can top that !What are the specifics of you Vette and does it have any mods? |
RE: TOP SPEED
Only a little over 120. Wasn't able to go any faster, safely that is.
It was pretty cool though, after about 95 it seemed like everything got real quiet, and she was running extremely smooth... |
RE: TOP SPEED
I don't own a Vette, but when I still had the 3.42 gears in the back before I upgraded them to the 3.73's, I hit 6200 RPM in 5th. By a gear calculater (since my speedo only goes up to 150 mph) it was 187. I don'tknow if it was really that fast, but I bet it was at least over 180.
RE: TOP SPEED
What car were you driving if not a vette?
When I calculate 5th at 6500 in a C5 with standard size tires and a 3.73, I get right at 170mph (a stock engine -- 300 RWHP -- would pull this if modified/reprogrammed to rev to 6500 instead of 6250). An M6 F-body (Camaro, Firebird) with standard size tires and 3.73 would doroughly the same mph at 6500 (this speed would require modifications to about 350 RWHP). A vette with a 3.73 would top out in 6th, if it could pull 6500 RPM, at about 220, at which speed it would need right around 600 RWHP. 196 mph with a 3.73 and standard size tires would be 5800 rpm in 6th with around 430-440 RWHP. |
RE: TOP SPEED
Again, this was done with 3.42 gears in my M6 Z28 (info in sig). I was at 6200 RPM in 5th gear which by a gear calculator would put me at 196. I don't know if it was really that fast or not since the speedo was buried. I know it was well over 180 though. 6th gear really didn't pull too much with the 3.42's, at that speed I put it in 6th and it barely would hold the speed, 5th gear was the only one that still pulled.
I will have to try it again sometime now that I have the 3.73's. Perhaps 6th gear will pull up top now. |
