Vendor Group And Special Buys Vendors and Advertisers will post special group buys for our members here! Check it out.
Improve your engine's efficiency with new aFe Black Series Momentum Air Intake
Old Aug 25, 2021 | 07:16 AM
carid's Avatar
Former Sponsor
Default Improve your engine's efficiency with new aFe Black Series Momentum Air Intake
aFe Momentum air intake systems are among the most popular in the company's product line. They are designed using the most up-to-date engineering tools and techniques to provide you with the perfect blend of power and protection. Recently aFe has expanded this line with a new Black Series Momentum Cold Air Intake, now available for 2015-2019 Chevy Corvette Z06. It features a custom CAD-designed roto-molded housing made from heat soak resistant cross-linked polyethylene to ensure the coolest air intake charge possible. A large clear sight window allows for filter inspection without removal of the airbox.
The housing is made out of lightweight high gloss, clear-coated plain weave carbon fiber and mounts directly into the factory location on the fender well to capture the coolest air. Momentum intakes are designed with fewer parts for a quick and simple installation. Premium stainless steel T-bolt clamps and a silicone hump coupling are used for strength and durability while also providing the most secure installation available.
Boost the performance of your Corvette's engine with a new aFe Black Series Momentum Air Intake!
aFe® - Black Series Momentum® Aluminum Black Carbon Fiber Cold Air Intake System with Pro 5R and Pro Dry S Gray Filter
https://www.carid.com/afe-power/mome...2-74202-c.html
Specifications:
  • HP Gain: Up to 46 hp
  • TQ Gain: Up to 39 lbs./ft.
  • Series: Black Series Momentum®
  • Filter Color: Gray
  • Tube Finish: Black Carbon Fiber
  • System Type: Cold Air Intakes
  • Material: Aluminum
  • Replacement Filter: Pro 5R and Pro Dry S # 21-90080
  • Airflow Rating: Up to 25%
Features:
  • High Quality One-Piece Roto-Molded Sealed Housing with Auxiliary Air Inlet
  • CAD-Designed Roto-Molded Intake Tube
  • Built-In Sight Window Provides Easy Inspection of Filter Without Disassembly
  • Unique (Patent Pending) Filter-to-Housing Interface for Easy Installation
  • No Cutting or Drilling on Factory Parts for Faster Installation
Includes:
- Unique Computer Design Carbon Fiber Housing with Sight Window
- Pro Dry S Oil Free and Pro 5R Oiled Air Filter
- Dyno-Tuned Carbon Fiber Intake Tube
- Premium Hardware
carid
May 27, 2021 06:33 AM
carid
Jul 13, 2018 09:41 AM
gigabyte
Aug 19, 2008 07:51 PM
stroker96
Aug 16, 2008 10:29 AM
PAY2PLAY
Nov 28, 2005 09:20 AM
