Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
C-4 Bose radio replacement
Old 01-10-2006, 04:02 AM
Psychoboy's Avatar
Default C-4 Bose radio replacement
I am looking for any info on how to replace the Bose radio. Cructhfield will sell you the radio and speakers, but they don't have any kind of mounting brackets or wiring harness; any info on where some one bought a good looking bracket and wiring for the car would be greatly appciated.
Old 01-24-2006, 12:48 AM
Default RE: C-4 Bose radio replacement
I had mine done. I'm using an Alpine head unit w/Infiniti 2ways up front 6x9 3 ways in the back and 2 10's in a bandpass in the hatch.
Old 02-27-2006, 09:45 AM
I replaced all of my Bose with aftermarket speakers. I took the speaker cabinets out and removed the guts and installed some good quality speakers without the Bose amplifiers in the boxes and reinstalled the boxes back in the doors and rear. They work great. You just have to figure out the wiring, it wasn't bad at all. [8D]
Old 05-01-2006, 01:42 PM
any one have any more detailed info... i will be installing a short throw b4 too much longer and while i have all that out i want to put in a pioneer head unit i have laying around... will i have to replace the speakers now? are they a different ohmage than what ill be pushing to them? do i have to remove/bypass any amps? is it a simple plug and play? anyone able to help that has installed one themselves?
Old 05-18-2006, 03:13 AM
just rip it all out and go aftermarket,you will be much happier
[IMG]local://upfiles/1664/6C110B6FCD0F44A08304952926C726F5.jpg[/IMG]
Old 12-10-2006, 11:58 PM
WideOne's Avatar
Preddy,
I just did this in my '84. Pioneerr 3800, two 6x9's in the back and 6 1/2 in the doors. Since it was Bose, everything had to go.
I used a dash kit and wiring adapter from Wally-World. Head unit in dash and rear speaker very easy. Speakers in door, very painful. Getting the old Bose enclosures out was a trck. I used adapters from Ebay in mounting the door speakers.
Sounds very nice and it was a good opertunity to replace dash/panel bulbs.
Whole deal was less than $300.00
Good Luck,
Randy
Old 07-08-2007, 10:43 PM
Your tuner pack is on the passenger side of the car buried in the dashboard where your glove box would be if you had one. a standard metra part number 70-1858 harness is a direct plug in adapter for an aftermarket stereo installation and you would just need to extend the wires to the radio location, as well as the antenna connection. as for the dash kit that will work you can contact metra at (800)221-0932 and they will happily tell you what dash kit it is and where to go to get one in your area. if your bose amps arent working properly then you may have to bypass them, they are located at each speaker location, inside the bose boxes that split into 2 halves after you remove about 10 screws from each one. you have to determine wich speaker leads are the inputs to the bose amp and splice them into the outputs to the speaker inside each bose box. the remote turn on lead in the metra harness is also for your power antenna...hope to god this works properly because it is costly and difficult to change the antenna in this car. If your looking for similar sound to what the bose system sounded like brand new then be prepared to shell out at least 8-15 hundred dollars for equipment and installation.
the best advise I can give you is if your looking at it....and it doesnt make sense to you...dont touch it!
Old 07-23-2007, 12:04 PM
Did you replace the Bose speaker wire when taking out the bose radio and speakers?
3BlkC4Ragtop
09-26-2008 09:51 PM
khaki1967
06-09-2007 09:53 PM
davedanisand
12-18-2006 06:53 PM
white88
07-26-2006 04:16 AM
markone
07-16-2006 11:00 AM
Quick Reply: C-4 Bose radio replacement
