c5 steering wheel lock up need help
Old 04-01-2014, 04:22 PM
AR Gangsta's Avatar
Default c5 steering wheel lock up need help
was up guys ..... i got a 2001 mn6 c5 vette car has never gave me a problem till now 75k on dash now . drove to the store and tried to turn it on and see on my dash (steering Wheel column lockd ) so i shook the steering Wheel clockwise hard that i was able to turn on the car an drive home an once i got home i was not able to turn it on no more once i parkd .my buddy let me barrow his by pass fix kit from corvette Houston i tried so many ways that it has me going nutts now from removing fuse 23,25,29 negetive cable for couple sec removing battery for 2 days reseting all codes in my dash the only thing that bothers me is the bypass kit was used 4 years ago an was never removed from his car till now wats the proper way to get rid of this problem can someone pls help me thanks
Old 04-02-2014, 08:15 PM
Not familiar w/ the C5 steering lock. Sounds like it is electrical in nature. They used to be mechanical w/ a cable running from the shifter to the steering column.
Old 05-25-2014, 08:40 PM
In order for the column lock bypass to work, you MUST start with the column, unlocked. If the bypass kit was never installed in your car, the dealership may install a blockoff plate (I know they did this for auto-transmission C5s).
linetrash1975
02-12-2013 12:27 PM
Baudier
06-19-2008 10:27 PM
Z06Wannabee
11-14-2007 09:37 PM
Corvette Queen
05-20-2007 09:02 PM
RDISRAELS
08-09-2006 05:42 PM
Quick Reply: c5 steering wheel lock up need help
