power window problem
Old Aug 30, 2008 | 10:42 AM
94 Black on Black's Avatar
Default power window problem
My windows worked fine until this morning. I went to put up my pass.side window and nothing happened. Driverside still works fine. When hitting the switch for the pass.side you can here a faint click from the pass. door.Could of my motor just up and died. It wasnt slow or anything before.
Old Aug 30, 2008 | 07:33 PM
Default RE: power window problem
ok i checked voltage at the motor.i unpluged the wires from the motor and i have 11.94 volts on both the blue and brown wire .i checked this with both door switches. is this telling me the motor is bad???
corvettekid
Oct 19, 2006 03:04 AM
Fuzzy74
May 11, 2006 01:06 AM
dcastine
Nov 22, 2005 07:16 PM
faleure
Oct 11, 2005 03:10 PM
Roger
Aug 29, 2005 10:49 PM
