C5 shifter knob
Old Nov 13, 2008 | 01:56 PM
MBR04's Avatar
Default C5 shifter ****
Is it possilbe to change out the stock shifter **** on a C5 auto transmission
Old Nov 13, 2008 | 03:09 PM
Default RE: C5 shifter ****
Absolutely:
Stock shift **** removal. At the bottom of the shift **** and facing the front of the car, there is what is effectively a sturdy staple that retains the stock shift **** in place. The legs of the staple are about 3/4 inch long. Using the tiny screwdriver, gently pry out and remove the staple. The staple should come out with moderate force or less, and once it is partially out you can pull it out with your fingers or the needle nose pliers. The room to pry under the staple is so slight that you may not be able to use a protective cloth. The head of the staple is shown in the photo, and note that the photo is taken from the front of the car looking downward.
Step 4b: Once the staple from step 4a is removed, the automatic shift **** simply slides off by lifting it upward.
You can buy an A4 shift **** adapter at Ecklers or other Corvette parts vendors so that any manual tranny C5 shift **** will fit.
Here's a picture of the adapter with a purple **** for a somewhat rare purple C5:
http://www.conceptualpolymer.com/images/PurpleA4.jpg
Old Dec 7, 2008 | 12:57 PM
deansreef's Avatar
how to change on a manual???
Old Dec 7, 2008 | 05:05 PM
ORIGINAL: deansreef
Step right in......
http://www.conceptualpolymer.com/corvette_install.htm
Dave
86Project
Jul 18, 2007 07:06 AM
Phill
Oct 22, 2006 02:02 AM
slw98vette
Apr 15, 2006 03:05 AM
hobbydays
Nov 20, 2005 02:49 AM
GranpapaTim
Sep 22, 2005 04:40 PM
