Creeking in back of 2000 vert
Old Nov 18, 2008 | 09:54 AM
john2517's Avatar
Default Creeking in back of 2000 vert
I recently started getting what I think is body creeking towards the rear of my 2000 vert. Is it possible that it could be suspension noise or just good old american car body noise. Car has 99,000 miles. Otherwise car is perfect.
Old Nov 18, 2008 | 02:27 PM
Default RE: Creeking in back of 2000 vert
Does this happen when you are taking off in first gear? If so, it could mean that one or more of the sway bar connections need to be tightened. I'll be checking mine out, soon when I change the oil.
Old Dec 2, 2008 | 02:25 PM
Update: I checked out the sway bar connection when the car was in the air my annual oil change and sure enough, the nut was loose. I tightened it by grabbing the threaded end of the bolt with rag-insulated pliers and then turning the nut with an open-end wrench. You can't just turn the nut as it won't tighten without your retraining the screw from rotating with the nut.
End result: That clunking noise upon takeoff is long gone!
mmikeclass06
Dec 24, 2008 08:09 PM
corvettecity99
Aug 30, 2007 01:31 PM
vern329
Sep 6, 2006 05:43 PM
Tyler
May 19, 2006 03:24 PM
sonicblu03
Feb 25, 2006 06:39 PM
