Mobil 1 oil ok in spring?
Old Mar 20, 2009 | 09:46 AM
trespasser8's Avatar
Question Mobil 1 oil ok in spring?
I know there are different opinions about oil changes in spring. A reliable source tells me if you change oil just before storage (Mobil 1) and DO NOT start the car for the usual 3-4 month storage period that the oil is fine you can leave it in. I guess the synthetic thing has a lot to do with it. Can I get some opinions on this??
Thanks to all you corvette guys!
95 Vette
Old Mar 20, 2009 | 02:54 PM
partsman41's Avatar
First,oil will not go "bad" while sitting,so if you don't run it,the oil will be fine. What kills oil is combustion by-products and moisture getting into it due to temperature changes resulting in condenstion. OIl changes in winter time should be time related normally 60 days,otherwise 5 or 6000 miles is normal for synthetics like Mobil 1.The additives in the oil are gradually consumed during normal use,more rapidly during severe weather. Also the molecule chains that grow during temperature rise are physically sheared by motor parts,causing a 5-30 oil to more closely resemble 5 than 30,not a good situation during high temp-high load operation. This is a very general littany on oil,but should help some?
Ron
Old Mar 20, 2009 | 04:27 PM
xfasteddiex's Avatar
moble 1 good all year i run it in my 69 ford ,05 harley, & 90 l-98
Old Mar 21, 2009 | 09:15 AM
Thanks for the confirmation partsman41.
Just another old guy trying to get along!
Old Mar 21, 2009 | 01:57 PM
scotth48's Avatar
I have been using Mobil 1 in several of my vehicles over the years. I am currently considering switchng over to AMS oil. Test results as compared to M1 look much better. I just got my '93 Corvette in Oct '08 and it has been in storage for winter and because I live in Michigan condensation can be a problem, so will change it and since I am going by what the previous owner has said about service on it, I will change oil in diff and trany also. I think there filters ar better also. I am considering becoming a dealer for there products. Check out there website.
grabie
Nov 15, 2007 03:59 PM
jdeatsch
May 22, 2007 09:46 AM
xbob17x
May 21, 2007 02:06 PM
SLJ2137694
May 16, 2006 02:32 PM
gnvenom
Jun 15, 2005 01:50 PM
