hood latch problem!!
Old Jan 21, 2006 | 07:03 PM
Robert's Avatar
Default hood latch problem!!
my 87 vette is my daily driver but im havin problems with my hood. The driver side latch is stuck closed and i have no idea how to fix it. I dont know how to get the hood open to even get to the latch. any coment would help im stuck cause i dont wanna drive it much till i can get that fixed. i dont wanna break down and then not be able to pop my hood either that would not be good at all.
Old Jan 21, 2006 | 10:29 PM
raisinbran's Avatar
Default RE: hood latch problem!!
it happened to me once. i would suggest driving around, and the vibrations should shake it loose. Im not gonna tell you how to fix it, because it still happens to me every now and then, so i obviously havent fixed the problem.
Old Jan 22, 2006 | 01:36 AM
lifelesslived17's Avatar
when you do get it open spray pb blaster (catalyst oil) into the latch mechanism and also try to get some into the metal sheating around the cable itself. this should rememdy the problem within several applications. ive also heard graphite spray works, but have not ever verified this for myself.
Old Jan 23, 2006 | 03:32 AM
raisinbran's Avatar
also try adjusting the cable tension by turning that long black screw right next to the latch.
Old Jan 24, 2006 | 10:26 PM
1fast86's Avatar
Ecklers Corvette supplies sells a tool for reaching in and opening the hood when it does not open such as yours. Can be found at ecklers.com
Old Jan 25, 2006 | 02:21 AM
1990veteman's Avatar
Mid-America - madvette.com and Corvette Central - corvettecentral.com should have that tool too.
Old Feb 18, 2006 | 03:38 PM
oldtvman's Avatar
my 84 did the same thing i had to manually removed the release handle and pull on the cables to get the hood open, then the problem was the latch system was gummed up and wouldn't respond a good light weight lubricant did the trick, the same thing happend on my jeep cherokee.
sandrail
Jul 11, 2006 08:15 AM
steve47714
May 18, 2006 02:29 AM
becuzitsthere
Mar 9, 2006 03:56 PM
Wifes81
Aug 12, 2005 12:28 AM
flower
Jun 23, 2005 02:57 PM
