rack and pinion on 85
Old Jan 24, 2006 | 03:06 PM
Clayton's Avatar
Default rack and pinion on 85
Good morning everyone,
I am having the rack and pinion on my 85 vette replaced while it's up on the rack getting the transmission rebuilt. Do I need to get a front end alignment after the rack is replaced? I'm sure that this is an absurd question but I've heard it both ways so I don't know. Any suggestions will be appreciated.
Clayton
Old Jan 24, 2006 | 03:51 PM
Default RE: rack and pinion on 85
I would get one. They are not much money and you can usually sit and wait for them to get done. You never know what all they will remove to make the rack and pinion install easier.
Old Jan 24, 2006 | 03:57 PM
Clayton's Avatar
that's what I thought too. Thanks for the recommendation.
Clayton
Old Jan 24, 2006 | 04:20 PM
ORIGINAL: Clayton
Clayton
no problem!
Old Jan 25, 2006 | 02:34 AM
1990veteman's Avatar
Definitely get it aligned....while you're replacing the rack...throw new tie rods on it too. There are two different Rack and pinion units available. A standard ratio and a sport ratio. Standard ratio is 2 3/4 turns lock to lock and sport ratio is 2 1/4 turns lock to lock. IMO I like the feel of the sport ratio. Both units are interchangeable. AND make double sure that they flush the power stearing system before hooking the hoses up to your new rack. Whatever caused the original rack to die is floating in around in the old fluid.
imb1987
Mar 28, 2011 10:45 PM
imb1987
Sep 14, 2008 09:20 PM
justc3s
Aug 30, 2006 10:19 PM
fullmonty
Jun 17, 2006 02:26 AM
lumpsdady
Apr 4, 2006 06:40 PM
