Service column lock & engine shut down
Old Jun 11, 2005 | 06:32 PM
boricua's Avatar
Default Service column lock & engine shut down
i I own a 1998 C5 Im haviing problems with my serviice column lock that was resolve and stering wheel moves free but engines shuts down when i try to run it . Is there any form to by-pass the cut off system from the BCM?. Thanks
Old Jun 12, 2005 | 11:40 AM
Default RE: Service column lock & engine shut down
im not exactly sure what youre asking...
Old Jun 12, 2005 | 08:37 PM
boricua's Avatar
After installing my service column lock by-pass Corvette C5 1998 steering wheel is free but engine shut off when i try to drive it, The question is how can i solve this problem? I think the BCM is probably receiving wrong information from the column lock by-pass... THANKS.
Old Jun 13, 2005 | 01:17 PM
so something that you installed is not allowing the car to run,...correct?
Old Jun 28, 2005 | 11:27 PM
bmwdiver's Avatar
if it was working fine before your installed the bypass, it's probably just the way in which you wired in the relay, if you let me know which wires you tapped in to I could possibly help. the only other thing it could be it the passlock resistor sensor in the switch, check the 2 wires that come off the front of the switch and run into there own 2 pin junction about a foot down the wire ( check to see if they became lose during your install that clean the contacts in the switch and on the key. good luck [sm=americanasmiley.gif]
Old Jun 29, 2005 | 11:50 PM
boricua's Avatar
Thank you I let you know if its works.
scotth48
Apr 27, 2009 09:29 PM
kruser
Jun 25, 2008 02:39 PM
Mercury
Jan 15, 2008 05:32 PM
peanut12
Jun 11, 2007 06:13 PM
jchiniski
Jan 22, 2007 09:06 PM
