Brake light is on :-(
Old Feb 14, 2006 | 10:57 AM
rmadursk's Avatar
Default Brake light is on :-(
I replaced the e-brake system from the front cable back on an 81 Vette and since then the brake light on the console stays on. Is there something that I can reset to turn it off?
I think it may have come on because the pedal went to the floor when I first tried the brakes. The slack in the rear pads had to be taken back up, but the pedal is solid now and the brakes work just fine. Plenty of fluid in the master cylinder. Plenty of pad all around?
How do I test the switch for the e-brake handle?
Thanks,
Ron Madurski
Old Mar 5, 2006 | 01:21 AM
CM77's Avatar
Default RE: Brake light is on :-(
iT SEEMS THAT YOU HAVE TWO DIFFRENT PROBLEMS, THE HAND BRAKE OR E-BRAKE IS A DIFFRENT SYSTEM FROM THE HYD. BRAKES. THE ONLY THING THEY HAVE IN COMMON IS THE REAR BRAKE ROTORS. IF THE PEDAL WENT TO THE FLOOR THERE IS A PROBLEM SOMEWHERE IN THE HYD. SYSTEM. THIS SHOULD BE CHECKED OUT ASAP, THIS IS ONE SYSTEM THAT NEEDS TO WORK 100% OF THE TIME. HOPE THIS HELPS.
Old Mar 6, 2006 | 02:01 PM
rmadursk's Avatar
Nope, just one problem. The brakes work fine. The pedal sinking initially was to take up the slack from spreading the pads apart to get them back over the rotor. I think it is the e-brake switch. It had done this before but I was able to clear it up by jiggling the switch. That didn't work this time.
Old Mar 7, 2006 | 09:46 AM
Find your proportioning valve, not sure of location, but the lines from your dual well master cylinder should lead to it. There should be a switch in the middle of the valve that should close when your brake pedal goes to the floor. Unplug the wire to the switch and see if the light goes out. If it does, you will have to replace the proportioning valve as the switch is shorted to ground. [8D]
Todd TCE
Aug 25, 2015 09:55 AM
Rons 95 Vette
Jun 26, 2006 12:32 AM
Sullyvette48
Mar 26, 2006 01:25 AM
UncleJessie68
Nov 25, 2005 01:38 AM
rcheath
Oct 24, 2005 11:02 AM
